Masoud Posted September 12, 2019 Share Posted September 12, 2019 (edited) Hi; When I toggle a node's flag to "Template", Houdini displays it in a gray color. How can I change color (brightness) of a template node? Thanks for helping. Edited September 12, 2019 by Masoud Quote Link to comment Share on other sites More sharing options...
Vishal Bakhaswala Posted September 12, 2019 Share Posted September 12, 2019 Have you tried with ctrl + RMB to fully view or see the template geometries in the viewport? Quote Link to comment Share on other sites More sharing options...
Masoud Posted September 13, 2019 Author Share Posted September 13, 2019 On 9/12/2019 at 7:29 PM, Vishal Bakhaswala said: Have you tried with ctrl + RMB to fully view or see the template geometries in the viewport? Expand You mean this? : Quote Link to comment Share on other sites More sharing options...
Vishal Bakhaswala Posted September 13, 2019 Share Posted September 13, 2019 (edited) On 9/13/2019 at 6:41 AM, Masoud said: You mean this? : Expand No, I mean Selectable Template to see into the viewport proper color which you're doesn't getting brightness of the color. Or If you're asking for template node viewport geometry wireframe colors that you can change in your houdini directory / houdini / config. There you will be able to find few different files. You can modify in that according to your color requirements. Edited September 13, 2019 by Vishal Bakhaswala Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted September 13, 2019 Share Posted September 13, 2019 I add a color node with the color I want then control click the display for selectable template flag. Quote Link to comment Share on other sites More sharing options...
Masoud Posted September 13, 2019 Author Share Posted September 13, 2019 Hi "Vishal"; As "ejr32123" said too, by turning on " Selectable Template Flag " and adding a color SOP, I changed Templated node's color, but the problem is I don't want it be selectable, and changing config file is not a good idea I think. Any other ideas? Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted September 13, 2019 Share Posted September 13, 2019 There is actually an easy way to adjust this. You can just adjust the viewport settings for the template only. (not selectable template) You can take it off ghosted, etc. 2 Quote Link to comment Share on other sites More sharing options...
Masoud Posted September 15, 2019 Author Share Posted September 15, 2019 On 9/13/2019 at 6:19 PM, ejr32123 said: There is actually an easy way to adjust this. You can just adjust the viewport settings for the template only. (not selectable template) You can take it off ghosted, etc. Expand Thank you "ejr32123", awesome. 1 Quote Link to comment Share on other sites More sharing options...
Vishal Bakhaswala Posted September 16, 2019 Share Posted September 16, 2019 On 9/13/2019 at 6:19 PM, ejr32123 said: There is actually an easy way to adjust this. You can just adjust the viewport settings for the template only. (not selectable template) You can take it off ghosted, etc. Expand Yes, this is the cool way to do. Thanks man. 1 Quote Link to comment Share on other sites More sharing options...
