Mozzarino Posted September 24, 2019 Share Posted September 24, 2019 While setting up vellum constraints, I used the preset: "configure balloon". It created both vellum constraints: cloth and pressure, with both nodes sharing the same "stretch" properties. After some testing, I realized that both "Stifness" and "Damping Ratio" could be set to 0 within the cloth constraint, as long as the pressure constraint had non-zero values on both parameters and things would be exactly the same. But on the other hand, if I tweaked the "Rest Length Scale" and "Compression Stiffness" parameters on the cloth constraint, this would have an impact. Why do some values on the cloth constraint are overriden by the pressure constraint (wich comes right after the cloth) and others aren't? Cheers, Diogo Quote Link to comment Share on other sites More sharing options...
anim Posted September 24, 2019 Share Posted September 24, 2019 I don't believe they are being overridden as they are setting values to completely different primitives, do you have a hip file? Quote Link to comment Share on other sites More sharing options...
Mozzarino Posted September 25, 2019 Author Share Posted September 25, 2019 13 hours ago, anim said: I don't believe they are being overridden as they are setting values to completely different primitives, do you have a hip file? Here it is. debug_vellum.hip Quote Link to comment Share on other sites More sharing options...
anim Posted September 25, 2019 Share Posted September 25, 2019 (edited) it's your vellumconstraintproperty1 nodeinside of the Vellum Solver which is controlling every constraint's stiffness so it is essentially overwriting the sop level values you may want to just limit it to pressure constraints if that is your intention so on vellumconstraints2 specify output group: pressure and on vellumconstraintproperty1 just use that group Edited September 25, 2019 by anim 1 Quote Link to comment Share on other sites More sharing options...
Mozzarino Posted September 26, 2019 Author Share Posted September 26, 2019 (edited) Ok, that clears it up for me! Thank you Edited September 26, 2019 by diogomgf Quote Link to comment Share on other sites More sharing options...
