texturing test geometry with redshift
Yes, you can grab the textures from the test geo if you right click and "allow editing of contents" then go to the shopnet and you'll see all the textures for example the pig head diffuse is
opdef:/Sop/testgeometry_pighead?lowres.jpg
You can use the same in the RS texture.
Make sure to turn off "add shader" in the test geo.
  • 2 weeks later...
thanks for your help
