COPS - Current Pixel Position ?
CinnamonMetal
2 hours ago, CinnamonMetal said:
That stinks, I can't duplicate the pixels if I can't set new positions for the pixels.
You can always create an array, store your data, « duplicate pixels » as you want with that array, and fill the new image (same resolution) with your result, no ?
11 hours ago, CinnamonMetal said:
I want to makes duplicates of only the input of a composite vop along an axis (x,y).
You don't need to set pixels position for that. You want to set the color of a pixels, so that it duplicates the color of other pixels. Example attached.
duplicateCOP.hip
@symek I'm assuming that is what @StepbyStepVFX meant in his reply ?
Although how can I change the aspect ratio of the composition view so that the butterflies are not stretched along the X when duplicating along the Y ? Also how can the, in your example duplicate the butterflies instead of a bi-directional axis in Y, either Y up, rather then Y up and down, vertically ?
