Import hda/otl with python
An_pi
As Dom mentioned, it's all in the docs but here's an example if needed.
# This code is the equivalent of running Assets -> Install Asset Library
hou.hda.installFile('path_to_your_hda_file_on_disk')
# Then you could create the HDA as you would normally with any other node
hda_node = hou_parent.createNode("OperatorType”, “Name”) # Operator Type is your hda type
-J
  • Thanks 1
