AlSk Posted October 22, 2019 Share Posted October 22, 2019 (edited) Studio Clipboard HDA Use case: You want to share OPs with colleagues super fast. And you want to spend minimal time to make this happen. Tl;DR: Just create an empty HDA to share arbitrary content. Creation: 1. Create an empty Subnetwork SOP 2. Create Digital Asset from it 3. Save it on a network location 4. Add the network location to houdini.env found in c:/Users/yourUser/Documents/houdini17.5/houdini.env by adding HOUDINI_OTLSCAN_PATH="z:/yourPathToCheapestHDAEver;&" Usage: 1. Create Studio Clipboard SOP 2. Allow Editing of Contents 3. Put OPs in you want to share 4. Save Node Type 5. Create Studio Clipboard SOP on another computer in the network 6. Retrieve content 7. Profit! Edited October 22, 2019 by AlSk 1 Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted October 22, 2019 Share Posted October 22, 2019 Another way is to send someone the copy and paste buffer file. Each network type has it's own copy and paste buffer file on disk whenever you copy something in Houdini. They can be emailed or put on network shares or whatever. 1 Quote Link to comment Share on other sites More sharing options...
AlSk Posted October 23, 2019 Author Share Posted October 23, 2019 (edited) How do I access the buffer file? Edit, found the answer: https://www.sidefx.com/forum/topic/49383/#post-223158 It's in c:\temp\houdini_temp\ under Windows. Also found this while researching the upper question. Clipboard History, a new Windows feature which seems quite handy. Though not for multple OP C&Ps. https://www.makeuseof.com/tag/windows-10-clipboard-paste/ Edited October 23, 2019 by AlSk Quote Link to comment Share on other sites More sharing options...
anim Posted October 23, 2019 Share Posted October 23, 2019 Or use following functions to save whatever nodes you want into file and load from there 1 Quote Link to comment Share on other sites More sharing options...
