Masoud Posted October 28, 2019 Share Posted October 28, 2019 Hi; When I render my test fire scene, it only shows smoke in Alpha channel and I can't see flames. Any idea? Thanks. Quote Link to comment Share on other sites More sharing options...
Masoud Posted October 29, 2019 Author Share Posted October 29, 2019 Any idea? Quote Link to comment Share on other sites More sharing options...
anim Posted October 29, 2019 Share Posted October 29, 2019 depends on your shader, fire is usually pure emissive shader so it doesn't have any Alpha if you are using Pyro Shader you can export fire_mask AOV which will be sort of like Alpha for your fire, but overall you may just want to have fire in separate emission AOV for comp anyway 1 Quote Link to comment Share on other sites More sharing options...
Masoud Posted November 2, 2019 Author Share Posted November 2, 2019 On 10/29/2019 at 6:40 AM, anim said: depends on your shader, fire is usually pure emissive shader so it doesn't have any Alpha if you are using Pyro Shader you can export fire_mask AOV which will be sort of like Alpha for your fire, but overall you may just want to have fire in separate emission AOV for comp anyway Expand Thank you. Quote Link to comment Share on other sites More sharing options...
