Issue with rendering fire Alpha channel...
depends on your shader, fire is usually pure emissive shader so it doesn't have any Alpha
if you are using Pyro Shader you can export fire_mask AOV which will be sort of like Alpha for your fire, but overall you may just want to have fire in separate emission AOV for comp anyway
Thank you.
