[SOLVED] vex groups question
Hi,
Probably easy question, but what would be the way to make this vex code shorter and work for more @id`s, so I don`t have to copy the same line of code multiple times?
if(@fid == 0)
    i@group_fid0 = 1;
if(@fid == 1)
    i@group_fid1 = 1;
if(@fid == 2)
    i@group_fid2 = 1;
if(@fid == 3)
    i@group_fid3 = 1;
I basically want to make a group for all primitives with same id.
I`m guessing it can be done using arrays, but I`m not too good with them.
Thanks
Janis
  On 10/29/2019 at 3:33 PM, ikoon said:
Hi Janis,
I assume that @fid is an integer. You can run this in a prim wrangle:
string group_name = "fid" + itoa(i@fid);
setprimgroup(0, group_name, @primnum, 1, "set");
Perfect. This is what I was looking for. Thanks
  On 10/29/2019 at 3:33 PM, Sepu said:
Use the partition Sop.
Nice one. This works nicely as well with fid`rint(@fid)`
Thanks guys!
Cheers
Janis
  • cudarsjanis changed the title to [SOLVED] vex groups question
