Redshift hair rendering (for Feathers)
Hi guys,
Any idea how I could to pass Cd point attribute to RS Hair shader? or any other point attribute.
Cd works only as prim attribute on curves.
I have done it with particles and primitives with ParticleAttributeLookup, but it doesn`t work on hair curves.
Weird thing is that @width works perfectly, by default. That is why I think I should be able to use any other point attribute that I create as well.
Any ideas?
RedshiftHair.hip
31 minutes ago, Sepu said:
I cant look at the file right now, but have a look at this
https://www.redshift3d.com/forums/viewthread/22890/
Thanks Hernan,
but I got this working as well, Cd as prim attribute. But then you cannot get ramp from bottom to tip. just one color for each hair :(
I would like to have control over color per point as we need to render feathers and look dev is gonna come from houdini with Cd attribute.
Cheers
Janis
I`ve found out this is a limitation for Redshift, currently curves don’t support point attributes. They only support attributes and UV coordinates at the primitive level, one value for all the curve points.
But...
https://www.redshift3d.com/forums/viewthread/25582/
Pinkmoonllc: "I did have my own work around, however. I imported Cd and multiplied it by the RS Ramp Node, which I left as white. See attached image. (requires uv vertex attr in sops)"
Will have to try this.
  • cudarsjanis changed the title to Redshift hair rendering (for Feathers)
I`m having 0 luck with this one unfortunately.
Here`s my .hip, if anyone want to play around with it or have some better idea.
Cheers
Janis
RsHairCdTest.hip
