Boolean shatter troubleshoot - failed
Marcocheng
Hello folks!
image.png.f13fc6643021e1f4195fcfa258c3627f.pngimage.png.eacfa291e092e6e3e92925dcb7801504.png
I have a pre-fractured piece which is a watertight mesh (from the previous simulation) and cutting plate (grid with noise) and planned to do a secondary fracture. Direct boolean fracture is failed to cut them apart. Meanwhile, when I VDB remesh the pieces before boolean fracture it works like a charm. Here's the network.
Fracture result:
LEFT(VDB remesh before shatter): The cutting is working as expected.
Mid(Regular remesher before shatter): The cutting is not working at all.
Right (Original pieces): The cutting is not working at all.
I tended to use the original pieces as I want to have the original UVs. But the fracture is failed. Any tips to prepare pieces to fit into boolean shatter tools? What's actually causing the problem here? Thanks!
File for troubleshooting:Booleanshatter_TroubleShoot.hip
