How can I control values of an "Attribute Randomize", by a "Ramp"?
Masoud
Hello guys;
How can I control Min/Max values of an "Attribute Randomize", by adding a "Ramp" channel to it?
I add these codes to min tab:
chramp("../att-ret/",0,0)
... and these codes to max tab:
chramp("../att-retime/",1,0)
but it doesn't work.
Thanks for helping.
that feature is already built-in by setting the distribution mode to "Custom Ramp". If you still want to do it your way make sure the chramp() has the correct path, in your case "threshold" instead of "../att-retime", then that should work too.
Edited by LucaScheller
