Opencl Functions
Drughi
Hi!
I'm doing some opencl scripting and it gives great speed improvements for example with pyro sims.
But I'm wondering about the functions. The gas turbulence_cl is a great reference.
Some Questions related to "compute_turbulence_cl":
1. It uses "lerpConstant", "fitTo01" without them being marked (turn cyan) in the editor. Also "lerpConstant" in vex is just "lerp", "fitTo01" is "fit01" - where to find those functions?
2. It obviously uses a noise. The noise gets imported to the kernel by calling "global const void  *theXNoise,". How is this working? Can I also import other stuff? Lets say another noise?
3. Is there a way to volume sample? If not by a prebuild function maybe selfmade?
If you look at the top it says:
#include <xnoise.h>
#include <interpolate.h>
These are files on disk with additional functions, like the noise or 'fitTo01'. They're located in Houdini 18.0.287/houdini/ocl/include.
I don't think you can sample other geometry with volumesample or point clouds with opencl, you have to specify everything you want to use in the kernel under the Bindings tab.
#include <xnoise.h>
Ah, awesome! So many new functions. Thanks!
