texture getting applied upside down
digiartist
17 hours ago, digiartist said:
when i am applying texture after rbd using uvtexture it is getting applied on the back side of my object after the simulation the texture remains unchange as if it is a different plane
i have attached my file please reply
Thank you
terrian_road_breaks-v24.hipnc
Hello and welcome to odforce.
First you should unpack geometry before applying uv. Some pieces you packed twice somewhere, therefore set iterations to 2.
Second, reverse x or y component of scale parameter for normal look of texture.
