Simplest way to show a texture in a viewport on a grid
guache
What's the simplest and most bullet-proof way to display a texture on a simple grid in Houdini viewport (i.e. real time openGL)? I've tried using simple materials (like "Constant" or "Principled") but it seems clunky. I always run into issues like requiring several settings in "Display properties" for the texture to show up, or the textures (read from files) not updating in the viewport, if I change the texture path etc. Ideally, the texture path would be just a string attribute on a grid, and the viewport would show it right away, and react to all path changes instantly.
Edited by guache
46 minutes ago, kleer001 said:
UV Quickshade SOP ?
Thanks, it seems simpler. I got the textures to show up and react to path changes instantly with the following Display Options:
Texture->Display Textures: On
Material->Use Materials: On
Material->Apply Material Stylesheets: On
Material->Apply Per-primitive Stylesheets: On
Material->Material Assignment: Always Update
Material->Interactively Update Materials: On
Lights->Quality->Headlight Only
Lights->Diffuse: On
