Free script to convert alembic cameras
Drughi
Hi!
I want to share with you a little script I did which I think is quite useful.
It allows you to convert for example alembic cameras to regular houdini cameras. Additionally it can scale cameras correctly and in general bake cameras.
You will find the script here: MyWebsite
Edited by Drughi
  • Thanks 1
  • 2 months later...
Hi John,
Thanks for the script. You might want to include all camera attributes that comes with the alembic file. also instead of baking it to frame range on houdini playbar, you can get the range exactly as it was exported using this line:
import _alembic_hom_extensions as abc
abc.alembicTimeRange(hou.ch("fileName"))[0] * hou.fps()
abc.alembicTimeRange(hou.ch("fileName"))[1] * hou.fps()
