Having subdivide issues
Houdini7
i am having some subdivide issues. when refining topology with it, points are not fused.
The result is this:
Of course you cannot simple use a fuse sop, because on the left side there is no point to fuse to. How can you solve this efficiently? (And I mean not to make an edge loop and fuse it.)
Thank you!
Edited by Houdini7
28 minutes ago, Skybar said:
Try changing the Algorithm on the Subdivide SOP. Use the Houdini or Mantra one, not OpenSubdiv.
Thanks, I knew this. But I need the OpenSubdiv Bilinear, because the change is linear, so it only subdivides. But I learned today, that you can use the H Catmull-Clark with Bias Parameter 0, which is the same! Thank you.
You can also enable "Override Crease Weight Attribute" and drag the slider :)
