RBD Impact shelf problem
Marcocheng
I've tried the impact shelf too to create a particle system in an impacted area. I use a simple sphere with Voronoi fracture. Default 5 Voronoi points work fine with the default Impact tool. But then I increase to 500 Voronoi point impact failed (no point display in the viewport or geo spreadsheet). Seems like more piece does not favor the impact tool. Any workaround method:(, how to setup proper RBD impact manually?
The only different is the scatter count.
Working - Five scatters point.
Not Working - 500 scatters point.
Impact_ShelfTool_Work.hip
Impact_ShelfTool_NotWorking.hip
Thanks:ph34r::ph34r:
