RBD concave thin wall collisions not detected
neurostudio
hey guys i am having a little bit of an issue with this test.
i picked up this setup from another thread on this forum however in this particular scenario it doesn't seem to work as i am probably missing something.
basically the pieces getting activated and falling, do not collide with the inner shrunk body volume i created and - since i am a houdini newbie - i am struggling to figure this out :)
tried to change geometry representation to concave, tried to increase resolution of colliders, but nothing worked so far.
i'd be really grateful if anyone could suggest a possible solution.
here's HIP and assets in case you want to have a look.
thank you in advance.
7 hours ago, bunker said:
You should use convex pieces with Bullet, the convex decomposition SOP can help with that.
convex pieces are slow and (very) buggy.
Hey Julien,
I am gonna give that a shot and report back. thank you :)
Edited by neurostudio
Hey Julien,
I have been implementing convex decomposition (probably the wrong way), and made a bit of a progress.
Would you mind having a look at my file? Assets .abc is included.
https://www.dropbox.com/s/eaheclpww2w090l/FRACTURE.zip?dl=0
thank you :)
I had a look at your HIP file, there was a few issues.
- the left side of the body didn't have a name attribute, same of the new faces from the PolyExtrude
- convex decomposition won't be consistent on animated geometry
a much better way is to create all your pieces on frame 1 and pointdeform them to transfer the animation.
for the activation, you can use a wrangle in DOPs and lookup your pointcloud directly.
girl_fracture_05_convex_decomposition2.hiplc
hope that makes sense.
Thank you so much :) Gonna dive in now and see if I learn something. Will let you know!
i had a look at your setup and certain things definitely make sense, even for a newbie like me! thank you!
however, collisions are still not working and the pieces fall straight through the collision volume. trying to figure it out!
1 hour ago, bunker said:
not sure what the dark blue object is but it should also be a convex packed primitive object.
julien, i think i am getting there :)
now  i need to exclude the collider (which is now a packed object) from the activation pop wrangle, but i really can't think of how.
girl_fracture_07_convex_decomposition.hiplc
2 hours ago, bunker said:
you can use the name attribute to filter out objects to activate in the pop wrangle:
eg: if your collider is named "collider"
if(s@name!="collider"){
// activate the other pieces
thanks julien!
now the collider is excluded, however the pieces collisions are not working properly.
trying to figure this out :)
alession odforce_01.hiplc
The blue collision object you are visualising... is that created using a static object dop? If so, are you visualising the "Collisions/RBD solver/Volume" tab rather than "Collisions/Bullet Data" tab??? I think you may not be seeing what the solver is seeing.
you should watch this, it's still relevant: https://www.sidefx.com/tutorials/h13-masterclass-bullet/
hey julien,
i kinda solved it... i got a little confused along the way, but tidied up things in the end :)
ended up getting rid of convex decompositions for both collider and rbd object.
used concave representation for both and reduced collision padding and split impulse threshold by a lot.
of course now it's super slow and the result isn't super stable, however it will work for what i need.
thanks guys for the help !
Glad you got it working, and of course whatever gets the job done is great. However, I would encourage you to investigate using convex hulls for all collisions. You will see vast improvements in speed and stability. They can be a little trickier to set up, but the rewards more than worth it.
will do cause honestly the sim is a little jittery and not all collisions are perfect :)
maybe i'll try this method next time.
thanks!
