How cant I increase fluid particles velocity, over time?
Masoud
7 hours ago, woodenduck said:
pop wrangle plugged in to "particle velocity" on the flip solver...
v@v *= fit(@Frame, 1, 24, 0, 1);
This will multiply your velocity on a ramp from 0-1 between frames 1 and 24.
It doesn't work.
instead of feeding initial velocity from SOPs, use POP Force DOP or other forces
force acts on velocity every timestep, therefore it will keep gradually increasing your particles velocity
you can also add some POP Drag or POP Wind to introduce some air resistance to not accelerate forever
Hi "anim",
The problem is I want to assign a fix, velocity noise to points, and when I use noise in a Dop, "POP VOP" node, it changes noise over time. I just want to scale velocity over time.
Edited by Masoud
then you can store your already computed v that you are happy with into some temporary attrib like v@tmpv using Attribute Swap SOP, method: Move
and in DOPs use POP Wrangle: v@force = v@tmpv * chf("weight");
it will use your v@tmpv vector (further scaled by weight parm) as a force
since force is added to velocity each timestep it will naturally accelerate, so just adjust weight to control the rate
Edited by anim
