flip fluid- sop solver vs pop wrangle
isah_voodoo
Hello,
I am currently diving into flip fluids and I have a few questions.
What is the difference between the sop solver and the pop wrangle in dops ?
If I were to set @v=(1,0,0) in a sop solver and then the same thing in a pop wrangle I will get pretty much the same effect...so what is the point of the sop solver? More control? Is the sop solver doing something intrinsically different than dops ? Isn't the point of a sop solver to basically remember the previous frame? Isn't that what dops is doing already ?
Thank you
Sop Solver is different to the solver on sop level.
Quote
No. The Dopnet itself is taking care of this.
The sop solver basicly allows u to use sops inside of dops, wich is very mighty.
Edited by Drughi
