Instantiate objects in Shader
So I want to instantiate objects in shader. There is a Point Instance Procedural VOP node. However I have no to little experience in shader builders in houdini.
This node has geometry output, I'm not sure where this even should be plugged in to make it to work and just see anything.
Any help would be super helpful! :)
On 1/28/2020 at 6:46 PM, Librarian said:
Or post an example of what  you need :wub:
Thanks! I will look into this!
Well... I need to instatiate geometry onto milions of points. Copying creates more expensive and slow cache. Example: grass
Edited by JJ FX
Try copying Packed Disk Primitives to your millions of points. Any .bgeo that you save to disk can be loaded in as a Packed Disk Primitive via the File SOP. As they are technically references to a file on disk, they don't need to be embedded into the .IFD and should be nice and lightweight.
The Point Instance Procedural workflow got messed up in the switch to the MAT context from SHOPs, and hasn't really been fully addressed since then. You're probably best off avoiding it.
