laplacian deformation?
Daniel
Hmm, Probably is. It's also similar to the Edit sop when using a smooth radius by connectivity. But I'm interested in seeing how this works as a live deformer, not an interactive sculpt.  I'll see if I can do it with delta mush
After playing with the deformer in Blender, it's quite different than Delta Mush. A bit hard to describe but it almost feels like it creates an ik relationship between all the edges in the mesh.. with just anchoring a couple of verts on either side of a mesh and pulling them apart it smoothly interpolates the verts between them using the connectivity of the mesh in a natural way.  There is code for the deformer on the Blender repository, might be worth trying to port
You have an example on odforce I think somewhere :)..
If you combine you can make a better tool.
Just install Anaconda python:) ..and you have a lot exampels for deformation and other fun..
https://houdinigubbins.wordpress.com/tag/laplacian/
https://wordpress.discretization.de/houdini/home/advanced-2/using-scipy-to-make-the-laplacian/
