While using CHOPs/MotionFX, what kind of script language can I use?
Masoud
10 hours ago, anim said:
it's just a message that the channel is overriden by CHOPs
when you export any channel from CHOPs to specific channel, that parameter will be driven by the channel value and shows that message
So, how can I override a channel manually? I mean when I create a CHOP network, how can I import a specific channel into my CHOP network?
not exactly sure what you are asking
you can use Fetch Parameters CHOP to get parameter values into chops
and any CHOP with Export flag on will export all it's channels to parameters in the scene if the Export Prefix + channel name result in a valid parameter path, also be aware of dependency loop, you don't want to export to the same parameters that you've imported (fetched), that's why Motion FX store the current parameter animation in a clip rather than fetching it live
Edited by anim
