Masoud Posted February 5, 2020 Share Posted February 5, 2020 Hi; When we add a MotionFX to a parameter, it adds some scripts in that channel. What kind of scripting language is that? (Please take a look at the image attached). Thanks. Quote Link to comment Share on other sites More sharing options...
anim Posted February 5, 2020 Share Posted February 5, 2020 it's just a message that the channel is overriden by CHOPs when you export any channel from CHOPs to specific channel, that parameter will be driven by the channel value and shows that message Quote Link to comment Share on other sites More sharing options...
Masoud Posted February 6, 2020 Author Share Posted February 6, 2020 10 hours ago, anim said: it's just a message that the channel is overriden by CHOPs when you export any channel from CHOPs to specific channel, that parameter will be driven by the channel value and shows that message So, how can I override a channel manually? I mean when I create a CHOP network, how can I import a specific channel into my CHOP network? Quote Link to comment Share on other sites More sharing options...
anim Posted February 6, 2020 Share Posted February 6, 2020 (edited) not exactly sure what you are asking you can use Fetch Parameters CHOP to get parameter values into chops and any CHOP with Export flag on will export all it's channels to parameters in the scene if the Export Prefix + channel name result in a valid parameter path, also be aware of dependency loop, you don't want to export to the same parameters that you've imported (fetched), that's why Motion FX store the current parameter animation in a clip rather than fetching it live Edited February 6, 2020 by anim Quote Link to comment Share on other sites More sharing options...
