whitewater of emit particle fluid error
jimsunglady
Your white water source node is not producing source volumes at all. The emission your getting is an error in general, it should not exist in the first place.
This is usually just a matter of tweaking your curvature/acceleration and vorticity settings.
Regardless of how you do it, when you display the "whitewatersource" node, you should see a volume of some kind where the emission takes place. It should not be blank.
The velocity of the fluid you're shooting across is high so the velocity volume created is sending the particles into random directions.
Edited by Feather
