Houdini 18 Hqueue jobs displayed failed but renderoutputs exist
Hi All !
Did anyone of you guys have Houdini 18 Hqueue issue?
In my case, After houdini 18 installation, I decided to upgrade hqueue (from 17,5) to 18.
The issue is : Everytime I submit a job to Hqueue, the IFD generation starts normally, till the last frame IFD is done and "master IFD generation job" shows me a "FAILED" status. After that, the clients assigned to render and maschines seem to be rendering. At the end of each frame the status of frame also turns to"FAILED". But when I check the render folder in the output directory, all renderings are done and look fine.  Did anyone have a chance to encounter such kinda problem?
Tried to downgrade back to 17,5, works good, as it should be. Upgrading also brings the upshown issue.
I'll be glad of any help.
