anicg Posted February 10, 2020 Share Posted February 10, 2020 (edited) I need to get rid of all primitives that: have more or less than 4 points, and of those that have 4 points, I need to delete the primitives that are not perfect rectangles (they don't need to be squares, I just need to get rid of the "distorted" rectangles Edited February 10, 2020 by anicg Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted February 10, 2020 Share Posted February 10, 2020 (edited) Hi, you can use primpoints() for example. remove_prim_by_pointcount.hipnc p.s. or use min_angle threshold ... remove_prim_by_pointcount_minangle.hipnc Edited February 10, 2020 by Aizatulin Quote Link to comment Share on other sites More sharing options...
animatrix Posted February 10, 2020 Share Posted February 10, 2020 Hi, you can do something like this inside a Primitive Wrangle and use the deviation parameter (from 0 to 1) to remove quad primitives based on how much one of its edges can deviate from the average edge length: float deviation = ch("deviation"); int count = primvertexcount ( 0, @primnum ); if ( count != 4 ) removeprim ( geoself ( ), @primnum, 1 ); else { int isclosed = primintrinsic ( geoself ( ), "closed", @primnum ); if ( isclosed ) { int pts [ ] = primpoints ( geoself ( ), @primnum ); float edgelen [ ] = { }; for ( int i = 0; i < len ( pts ) - 1; ++i ) { vector p0 = point ( geoself ( ), "P", pts [ i ] ); vector p1 = point ( geoself ( ), "P", pts [ i + 1 ] ); append ( edgelen, distance2 ( p0, p1 ) ); } float perim = primintrinsic ( geoself ( ), "measuredperimeter", @primnum ); perim *= perim; float avgperim = perim / count; foreach ( float elen; edgelen ) { if ( abs ( elen - avgperim ) / avgperim < deviation ) { removeprim ( geoself ( ), @primnum, 1 ); break; } } } } 1 Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted February 10, 2020 Share Posted February 10, 2020 Hi Mani, a rectangle is defined by having four corners with rectangular angles. So first get rid of non-quads in a primitive wrangle: if(primvertexcount(0, i@primnum) != 4){ removeprim(0, i@primnum, 1); } Then create vertex attributes with the direction from one vertex to the next (and the number of the next vertex): int num_vtx = primvertexcount(0, i@primnum); int index_curr = vertexprimindex(0, i@vtxnum); int index_next = (index_curr + 1) % num_vtx; int vtx_next = primvertex(0, i@primnum, index_next); int pt_curr = vertexpoint(0, i@vtxnum); int pt_next = vertexpoint(0, vtx_next); vector pos_curr = point(0, 'P', pt_curr); vector pos_next = point(0, 'P', pt_next); vector dir = normalize(pos_next - pos_curr); v@dir = dir; i@vtx_next = vtx_next; Lastly you would filter out primitives by their inner angle between consecutive vertices: float tol = chf('tolerance'); int vtx[] = primvertices(0, i@primnum); foreach(int vt; vtx){ int vtx_next = vertex(0, 'vtx_next', vt); vector dir_0 = vertex(0, 'dir', vt); vector dir_1 = vertex(0, 'dir', vtx_next); float angle = dot(dir_0, dir_1); if(abs(angle) > tol){ removeprim(0, i@primnum, 1); break; } } keep_rect_quads.hipnc 1 Quote Link to comment Share on other sites More sharing options...
davpe Posted February 11, 2020 Share Posted February 11, 2020 and what about, after removing non-quads, just testing (in loop per prim) whether the perimeter of a primitive (using measure SOP) is equal to a distance between any two points multiplied by 4? does it make sense? Quote Link to comment Share on other sites More sharing options...
