richnosworthy Posted February 12, 2020 Share Posted February 12, 2020 Hey everyone, this has been bugging me all day. I've got two polygons with identical number of points, but when i skin them i can't get a clean surface. I thought shifting the point order would do it but it doesn't change anything. Can anyone explain why this is the case with skin? I know this could be done with polybridge too, but this is actually for a seperate task where i've gotta use nurbs curves - and seems to be the same issue there. Thanks skinissues.hipnc Quote Link to comment Share on other sites More sharing options...
Skybar Posted February 12, 2020 Share Posted February 12, 2020 Seems to work if you put down a PolyPath SOP after the Sort SOP and then just adjust the Offset on the Sort SOP so it matches up. Quote Link to comment Share on other sites More sharing options...
anim Posted February 12, 2020 Share Posted February 12, 2020 you need to shift order of primitive vertices, the point order doesn't matter so use Primitive SOP/Face/Hull/Vertex/Shift offset instead of Sort SOP 1 Quote Link to comment Share on other sites More sharing options...
richnosworthy Posted February 12, 2020 Author Share Posted February 12, 2020 Ah man, thanks so much. Of course it makes sense now. Cheers Tomas Quote Link to comment Share on other sites More sharing options...
