opunhide all nodes using python
younglegend
  • younglegend changed the title to opunhide all nodes using python
  On 2/17/2020 at 6:02 PM, anim said:
hou.hscript("opunhide Sop point")
should work
oh you're right, it does. Had to restart houdini for some reason.
ok so hou.hscript("opunhide Sop") gives me all the hidden sop nodes but since it's returns a string, how do you make it a list so that i can loop for each node and say hou.hscript("opunhide Sop <node_name>")
sop_list = []
for i in hou.hscript("opunhide Sop"):
    sop_list.append(str(i))
for sop in _sop_list:
  node _name = (sop.split(" ")[-1])
  print node_name
This won't work as i realized t's returning a string, not list of nodes  :blink:
sop_list = hou.hscript("opunhide Sop")[0].split()[2::3]
for sop in sop_list:
    hou.hscript("opunhide Sop {}".format(sop))
or if you want to unhide all nodes of all types
all = hou.hscript("opunhide")[0].split()
node_list = [all[i+1:i+3] for i in range(0, len(all), 3) ]
for node in node_list:
    hou.hscript("opunhide {} {}".format(node[0], node[1]))
Edited by anim
That's perfect. Thanks Tomas ^_^
