Map Box Node Texture
I've started playing around with the Mapbox Noce in the SideFX Labs Tool Box and its fantastic. But I've found a bit of a problem that I can't work out. Is there a way I can extract the texture or Cd into a compositing node then into a shader while keeping it all within Houdini with exporting anything? I'm using Houdini Apprentice anything I export out is limited resolution wise.
Hi Oliver
I think if you look inside the mapbox node you will find a cop network which you can reference from your material. If you cannot enter the node , right click and select 'allow editing of content'.
Look up the "op:/img/ "  expression. You will probably end up writing something like this - /obj/geo1/sop_mapbox1/cop2net1/OUT.
Thanks
John
Edited by hughspeers
grammer
