Alembic particles to C4D
PixelNinja
I spent a fair bit of time trying to figure this out today so I figured I'd post a quick tutorial for posterity.
The only other guides and info I could find were specific to getting pscale and Cd into C4d for Redshift. Nothing on orientation or other attributes generally.
Long story short:
- Unless your attribute is explicitly typed (i.e. Vector, Quaternion, Matrix instead of 3flt, 4flt, 9flt) C4d will read it as a float (or "Real")
- Orientation is handled by the "Alignment" TP channel, so you need to convert your @orient to a matrix3 before export
Hope this saves someone else some time.
  • Thanks 2
1 hour ago, flcc said:
Usefull for me anyway.
Yes TP is a bit tricky.
For now I just use pscale and age and i get it work, but for sure it'll save me a headache when I want to use an other than float attribute.
Yeah most of the time pscale and age are all you need.
I recently had to deal with instancing with orientation though and it took me a fair bit of frustration trying to figure it out.
Glad you found it helpful!
  • 7 months later...
  • 3 weeks later...
  • 4 months later...
