h18 sop bullet solver- constraints
logix1390
Hello,
I am trying to do something pretty simple using the new h18 sop level bullet solver..
I want to merge in two different Glue constraints, each with a different data name ("Glue" "and "Glue_Two"). Then  I want to break each unique glue constraint on a specific frame.
It seems as if I technically got it working,  but for some reason my constraints are not maintaining its strength.  I have them both set to -1 which means it should never break until told to do so.
I feel like I am not setting up the data names on the bullet solver properly...
I will attach my file for anyone that wants to take a look.
Thank you.
rbdBullet_constraints.hipnc
ohh....man this is a real noice gotcha.....
say you adjusted the scene above, to break the 2nd wall at frame72, it does jack $hit...
go into Advanced>Bullet Solver>Sleeping Time, increase that to 5 say....works !!!
Alternatively, leave Sleeping Time at 2, increase Contact Breaking Threshold....works too....what's the correct way ? I have NFI.
Edited by Noobini
@Noobini Thank you for the response. Yeah that is very weird how it doesn't work when you change the frame number .  Your tips worked .  I will need to do more testing myself. .
 I was confused about merging in multiple constraints with different data names... but apparently if I am using multiple glue constraints, you can only use 1 data name and use the grouping options to control them separately.
Thanks
