how to render panoramic image with mantra like Redshift camera?
hi guys, I tested panoramic rendering for 360 circle vision movie.
This is rendered with Redshift. So I set the camera, View projection : Cylindrical(panoramic) and set Horizontal FOV to 360, Vertical FOV 180 in the Redshift Camera Settings tab.
That is easy!
But I want to same render images with mantra.
Is there any way for camera setting or lens shader?
please help, thanks.
Edited by shinsso
yes, if the Cylindrical (panoramic)  or Polar (panoramic) don't render in Mantra exactly how you wan't, you can always switch Projection to Lens Shader and provide CVEX shader that does what you need
