Hyrulean Posted March 8, 2020 Share Posted March 8, 2020 Hello everyone! I am trying to do a simple thing but it seems like I am missing something. I want something similar to this: But instead of controlling it by pscale, I would like to take the bounds of my instancing objects and make them get away from each other if the bounds of the instanced object is bigger than the distance between the points, or maybe deleting them as well. I am trying to do this just to scatter some crowds in a field, is there is an easier way to do that, it would be nice to know as well as I am quite new to crowds. I am attaching a simple example file of what I am trying to do. Crowd_RND_01.hip Quote Link to comment Share on other sites More sharing options...
Noobini Posted March 9, 2020 Share Posted March 9, 2020 - not sure why you randomize Max/Min to the same value...might as well set every Tom/Dick/Harry = 0.868391 - instead of using box, use bounds, set bounding type to rectangle, you get a nice footprint (can even orient the rectangle) then I think area makes more sense than the total area of a 3d box. Quote Link to comment Share on other sites More sharing options...
Noobini Posted March 9, 2020 Share Posted March 9, 2020 (edited) just foolin' around abit Off topic: there's a convenient Radii Attribute in bound, it outputs detail radii[0] radii[1] radii[2] They are halflengths for a bounding rectangle (or box)...could be useful for proxy radius tho not as accurate as using trig to workout the radius but how the HELL do i access these ? the only thing that worked was: detail("../blah","radii",0)...how to access radii[1] ? vu_Crowd_RND_01.hiplcFetching info... Edited March 9, 2020 by Noobini Quote Link to comment Share on other sites More sharing options...
Noobini Posted March 9, 2020 Share Posted March 9, 2020 hmmm...FYI, you can see the detail("../bound1","radii",1) works perfectly in the Circle SOP yet if I use that same VEX func in the wrangle, NO dice...no matter what I tried, in the end I simply refer to the chanel in the circle...PIA ! vu_Crowd_RND_radii.hiplc 1 Quote Link to comment Share on other sites More sharing options...
davpe Posted March 9, 2020 Share Posted March 9, 2020 On 3/9/2020 at 7:43 AM, Noobini said: hmmm...FYI, you can see the detail("../bound1","radii",1) works perfectly in the Circle SOP yet if I use that same VEX func in the wrangle, NO dice...no matter what I tried, in the end I simply refer to the chanel in the circle...PIA ! vu_Crowd_RND_radii.hiplcFetching info... Expand in wrangle you just use node input numbers, instead of a network path: detail(0, 'radii', 1); Quote Link to comment Share on other sites More sharing options...
Noobini Posted March 9, 2020 Share Posted March 9, 2020 (edited) On 3/9/2020 at 8:35 AM, davpe said: in wrangle you just use node input numbers, instead of a network path: detail(0, 'radii', 1); Expand could have sworn i tried that first off, ie connected it to 2nd input of wrangle, then tried all 0,1,2 indices. , 1st input was for the points that was gonna set f@brad value for. Edited March 9, 2020 by Noobini Quote Link to comment Share on other sites More sharing options...
Hyrulean Posted March 9, 2020 Author Share Posted March 9, 2020 Thanks guys! This is exactly what I needed! Quote Link to comment Share on other sites More sharing options...
