saca Posted March 9, 2020 Share Posted March 9, 2020 pyro solver and smoke object generate smoke and fire, but this default setting simular result by every one. if you want to use new noise turbulence or new shape desined noise, use micro solver in "Velocity-update" or "Acvection"? which solver uing? example, spheric or box pattern. thanks. Quote Link to comment Share on other sites More sharing options...
saca Posted March 9, 2020 Author Share Posted March 9, 2020 sorry my poor english Simply say. for smoke motion, what if you want to use a completely different pattern as turbulence? This is not necessarily a noise pattern. It may be a forced straight line or a box-like pattern. In such a case, other software will apply an arbitrary 3D map, but what is the similar method in Houdini? Quote Link to comment Share on other sites More sharing options...
Atom Posted March 9, 2020 Share Posted March 9, 2020 (edited) Disable Turbulence on shape tab. Add GasOpenCL, connect to Velocity Update and change the code. #include <xnoise.h> #include <interpolate.h> kernel void gasturbulence( int stride_x, int stride_y, int stride_z, int stride_offset, float orig_x, float orig_y, float orig_z, float voxelsize_x, float voxelsize_y, float voxelsize_z, float timeinc, float time, global const void *theXNoise, float amp, float rough, float4 freq, float4 offset, float atten, int turb, int use_control_field, float control_min, float control_max, float control_threshold, float control_influence, int remap_control_field, int controlramp_size, constant float *controlramp_vals, global float *vel_x, global float *vel_y, global float *vel_z, global const float *density, global const float *forcescale ) { size_t x = get_global_id(0); size_t y = get_global_id(1); size_t z = get_global_id(2); size_t idx = stride_offset + x * stride_x + y * stride_y + z * stride_z; // Voxel position in in local space. float3 voxpos = (float3)(orig_x + (x + 0.5f) * voxelsize_x, orig_y + (y + 0.5f) * voxelsize_y, orig_z + (z + 0.5f) * voxelsize_z); // 4D position float4 P = (float4)(voxpos, time); float3 v = 0; if (density[idx] > control_threshold) { float scale = 1; if (use_control_field) { // Fit to 0-1. scale = fitTo01(forcescale[idx], control_min, control_max); if (remap_control_field) scale = lerpConstant(controlramp_vals, controlramp_size, scale); scale += (1 - scale) * (1 - control_influence); } P *= freq; P -= offset; // The call to vop_simplexCurlNoiseVP in vop_curlNoiseVP multiplies // roughness by 2 (maybe to match original finite differencing scheme?) rough *= 2; for (int i = 0; i < turb; i++, P *= 2.0f, scale *= rough) v += scale * curlxnoise4(theXNoise, P); if (atten != 1) v = pow(v, atten); v *= amp * (timeinc * 24); } vel_x[idx] = v.x; vel_y[idx] = v.y; vel_z[idx] = v.z; } All that is really happening is a modification to the velocity field. Edited March 9, 2020 by Atom Quote Link to comment Share on other sites More sharing options...
saca Posted March 13, 2020 Author Share Posted March 13, 2020 thanks, but is there more image based way? that's very hard programming for me. Quote Link to comment Share on other sites More sharing options...
bunker Posted March 14, 2020 Share Posted March 14, 2020 you could use VOPs if you don't like code https://www.sidefx.com/docs/houdini/nodes/vop/unifiednoise.html for a box-like pattern, have a look inside the gasDisturb DOP node Quote Link to comment Share on other sites More sharing options...
Atom Posted March 14, 2020 Share Posted March 14, 2020 You could try the fried chicken approach and create velocity vectors using an AttributeFromMap. Quote Link to comment Share on other sites More sharing options...
