CinnamonMetal Posted March 15, 2020 Share Posted March 15, 2020 I have a scene I found online which uses this expression for an RBD simulation in the activation of the Modify Data DOP ; dopnumrecords("../../AutoDopNetwork", $OBJID, "Impacts", "Impacts") I can't find the Impact records anywhere within the scenes AutoDopNetwork ? Quote Link to comment Share on other sites More sharing options...
bunker Posted March 16, 2020 Share Posted March 16, 2020 put down a Sopsolver inside DOPs, everything is ready on the "impacts" node. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 17, 2020 Author Share Posted March 17, 2020 (edited) The second file from here; there is no SopSolver so how is the impact data being read and found ? Edited March 17, 2020 by CinnamonMetal Quote Link to comment Share on other sites More sharing options...
bunker Posted March 18, 2020 Share Posted March 18, 2020 sorry I though you wanted the impacts points but you want the actual records, a bit different. you'll see the impacts in DOPs under DopObject/Impacts but only on the frames where you get impacts: Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 18, 2020 Author Share Posted March 18, 2020 (edited) @bunker Records are in this case, the sub-Impact within the Impact ? The expression dopnumrecords is attaching the data to the position data, in a modify data dop, correct ? If the dopnumrecords is applied to the Activation of the modify data dop, shouldn't when the impact applies, the value for the Activation change to 1, rather then stay at 0 ? Also where can I find the value created from the Modify data dop in the spreadsheet; I search within position and impacts, I find nothing ? Edited March 19, 2020 by CinnamonMetal Quote Link to comment Share on other sites More sharing options...
bunker Posted March 24, 2020 Share Posted March 24, 2020 not sure what you're doing with the modify data DOP, it's just a like setting a value on an attribute, it really depends what you do with it. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 25, 2020 Author Share Posted March 25, 2020 I have it figured out Thanks for your help though Quote Link to comment Share on other sites More sharing options...
