Earth Destruction // Cloud layers follow RBD destruction SIM of Earth
So I am currently working on an earth destruction sequenz were I have 2 layers on top of the earth base which I fractured and is going to collide with an object.
I am a little uncertain on how I should go about getting the other two layer to follow the rbd SIM without having to sim everything 3 times.
Just a hint or an idea into the right direction would be enough for me. :)
Cheers,
Pascal X
Cheers,
Pascal X
I solved it by just using the same fractured object as for the earth scaling them up a bit so thay lay above earth and blasting the inside pieces and assigning the material in the sop. :)
