Volume strange result Redshift
You can not manipulate the Emission gradient that way. There must always be a black chit on the far left 0.0 position of the gradient. That effectively masks out all that temperature noise. Lock that position down, then place a companion color chit next to it to achieve your look.
Edited by Atom
Yep, but here is a screenshot, the first is the problematic scene, I've changed the shader with the one I use with the second screenshot and I have again a bad result ?
truc.hiplc
