cirakcemal Posted March 27, 2020 Share Posted March 27, 2020 Hi everyone. I have a question to you. I downloaded renderman 23 into Houdini 18. And then I downloaded Arnold into Houdini. But both these render motors aren’t working at the same time. What should I write env. exactly? Quote Link to comment Share on other sites More sharing options...
Atom Posted March 28, 2020 Share Posted March 28, 2020 Here are my settings for Renderman 23.0. It assumes a default install on a Windows system. HOUDINI_PATH = "C:/ProgramData/Redshift/Plugins/Houdini/18.0.287;@/python2.7libs;&" HOUDINI_DEFAULT_RIB_RENDERER=prman23.0 RMANTREE="C:\Program Files\Pixar\RenderManProServer-23.0" RFHTREE="C:\Program Files\Pixar\RenderManForHoudini-23.0" RMAN_PROCEDURALPATH=$RFHTREE\18.0\openvdb;& HOUDINI_PATH=$RFHTREE\18.0;$HOUDINI_PATH;& PATH=$PATH;$RMANTREE\bin;& I also have the RMANTREE system environment variable set to. C:\Program Files\Pixar\RenderManProServer-23.0\ 1 Quote Link to comment Share on other sites More sharing options...
cirakcemal Posted March 28, 2020 Author Share Posted March 28, 2020 Thank you for the answer Atom. This is my setting. Its working. 1 Quote Link to comment Share on other sites More sharing options...
duveil Posted August 25, 2021 Share Posted August 25, 2021 I use packages for installing different render engines. Arnold and redshift are working fine. But I never tried renderman I attach my redshift json file . You can check the syntax . Redshift.json Quote Link to comment Share on other sites More sharing options...
