HDA loop not updating
Dumarus
Hi guys.
I have a problem with one of my HDA's.
I have 3 parallel loops. The first one is looking for a number of iterations to run out of points and stop by triggering Stop Condition.
The second and Third loop is using a number of iterations from the first loop. Problem is that the first loop does not update when HDA is inside a loop. I have to select the first loop output and then it works.
UPDATE: I thought that the problem is that the first loop is parallel to the one dependent on it, but after I added it to the flow and it is before the 2 others it is still not updating.
Any way out?
