Pyro Sim For Uni Project
lapd100
So for my uni project i need to put fire on some bowling pins while they are being juggled. Im struggling to get the fire to flow correctly as if its being thrown. Ill link my files so people can take a look. Ive messed around with all the setting and i cant seem to tone down the fire. The screenshot i posted on this post has the fire being really blown up even tho all the settings are quite low. I would appreciate any help.
Capture.PNG Pyro Sim.zipFetching info...
Edited by lapd100
.abc files are alembic files, which I presume contain your bowling pins. Your source for your pyro is coming from an object merge (/obj/geo1/object_merge1)
which is referencing a number of different alembic sops, which in turn are referencing alembic files on disk. These path are hard coded to path outside of the
zip file you uploaded (for example C:/Users/Liam/Desktop/Juggling_Loop/Juggling_Loop/cache/alembic/Pins.abc). If we don't have these files we can't help you.
