houdini pytho pyqt4 button event
When I create a button event in Houdini pyqt4, I want to create another event from that selected button.
example
def btn1_clicked(self):
        camList = []
        globj = hou.node('/obj/')
        for child in globj.children():
            nameOrder = list(child.type().namespaceOrder())
            if 'gl_Camera_' in nameOrder:
                camList.append(child.path()+'/fx_renderCam')
            elif 'cam' in nameOrder:
                camList.append(child.path())
        camCount = len(camList)
        if camCount == 0:
            choiceCamPath = 'None'
            sh_render = hou.node('/out').createNode('gl_Mantra_','RENDER_shadow')
            sh_render.moveToGoodPosition()
            #sh_render.setColor(hou.color((1,2,3)))
            sh_mat = hou.node('/mat').createNode('shadowmatte')
            sh_mat.moveToGoodPosition()
            sh_render.parm('camera').set('None')
            hou.ui.displayMessage('no cam.')
        elif camCount > 1:
            camList.append('Cancel')
            choiceCam = hou.ui.displayMessage('choice cam.', buttons=camList , severity=hou.severityType.Message, close_choice=camCount) <-  If 'cancel' is clicked, the node is not created at the out level and the message window is turned off.
            choiceCamPath = camList[choiceCam]
       #     if buttons==camCount:
        #       self.close()
            else:
                sh_render.parm('camera').set(choiceCamPath)
This is part of the script to automatically create the shadow mat I am creating.
Thank you for your help.
Please display your code using the insert code, would be much easier to read.
The hou.ui.displayMessage function returns the id for the button clicked (i.e 0 for the 1st button, 1 for the second...) so I assume you can do something like this :
mybuttons = ["cam1", "cam2", "cam3", "cancel"]
returned_button = hou.ui.displayMessage("my message", buttons = mybuttons, close_choice = (len(my_buttons) -1))
if returned_button == (len(mybuttons) - 1):  #don't forget to subtract one of your list length to get the right index, otherwise you'll get the wrong one
    do something
    do something else
Cheers,
Edited by DonRomano
    do something
    do something else
Cheers,
Thank you for your support!!!!
