houdiniwhy Posted April 11, 2020 Share Posted April 11, 2020 Hi. i am building rbd destruction simulations. i am trying to use Switch node to erase the frag line from fractured obj before rbd simulation started. what kind expression should i use with the node? or is there better way to erase those lines? Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 11, 2020 Share Posted April 11, 2020 (edited) rbdconnectedfaces ? (and rbddisconnectedfaces) Edited April 11, 2020 by Noobini Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 11, 2020 Share Posted April 11, 2020 are you thinking like glass...you don't want to see anything (edges) broken UNTIL it is physically broken ? Quote Link to comment Share on other sites More sharing options...
houdiniwhy Posted April 11, 2020 Author Share Posted April 11, 2020 Just now, Noobini said: are you thinking like glass...you don't want to see anything (edges) broken UNTIL it is physically broken ? yes exactly !!!! i am making wall destruction. even before the breaking collision goes on, my wall already seems fractured.. Quote Link to comment Share on other sites More sharing options...
houdiniwhy Posted April 11, 2020 Author Share Posted April 11, 2020 4 minutes ago, Noobini said: rbdconnectedfaces ? aw i don't use version 18. so i can't use it Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 11, 2020 Share Posted April 11, 2020 Just now, houdiniwhy said: aw i don't use version 18. so i can't use it goooooo on take the plunge!!! Quote Link to comment Share on other sites More sharing options...
houdiniwhy Posted April 11, 2020 Author Share Posted April 11, 2020 10 minutes ago, Noobini said: goooooo on take the plunge!!! by the way, isn't the node only available to use when it used with 'rbd material fracture node'? Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 11, 2020 Share Posted April 11, 2020 10 minutes ago, houdiniwhy said: by the way, isn't the node only available to use when it used with 'rbd material fracture node'? does sound like it with the rbd prefix...but i just did a quick test with vorofrac and it didn't complain. Quote Link to comment Share on other sites More sharing options...
houdiniwhy Posted April 11, 2020 Author Share Posted April 11, 2020 2 minutes ago, Noobini said: does sound like it with the rbd prefix...but i just did a quick test with vorofrac and it didn't complain. can you please show me an example..? sorry for asking.. Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 11, 2020 Share Posted April 11, 2020 it's with H18 tho...do you have it? Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 11, 2020 Share Posted April 11, 2020 so for less than H18, can't you use the old switch trick ? ie. use orig geo before break, at break switch to the fractured geo Quote Link to comment Share on other sites More sharing options...
houdiniwhy Posted April 11, 2020 Author Share Posted April 11, 2020 4 minutes ago, Noobini said: so for less than H18, can't you use the old switch trick ? ie. use orig geo before break, at break switch to the fractured geo oh thanks! should i use VEX on switch node?? otherwise, how does the node knows when to start..? Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 11, 2020 Share Posted April 11, 2020 Just now, houdiniwhy said: oh thanks! should i use VEX on switch node?? otherwise, how does the node knows when to start..? well you know when the break starts right ? say the ball hits the window at frame 30, then in the switch, connect unbroken window 1st, then connect broken window 2nd, then in select input: $F>30 Quote Link to comment Share on other sites More sharing options...
houdiniwhy Posted April 11, 2020 Author Share Posted April 11, 2020 10 minutes ago, Noobini said: well you know when the break starts right ? say the ball hits the window at frame 30, then in the switch, connect unbroken window 1st, then connect broken window 2nd, then in select input: $F>30 thank you very much! i will try it right now :)) well its actually breaking two times. like one time at 12frame and one time at 90frame. hope it works!!!! Quote Link to comment Share on other sites More sharing options...
