Wetmaps are not visible
digiartist
not quite sure....but I put the pcfilter2 to wet rather than P...seems to work.
(oh and change to float channel too)
(but it takes awhile to get to the effect tho...like around frame 186...you know what you've done, I don't :))
Edited by Noobini
  • 2 weeks later...
  • 1 year later...
On 22.04.2020 at 8:00 PM, ronit1996 said:
Hello @digiartist, here's a simple wet map technique for you, I used your file just changed the final wetmap technique, you can ask if you have any doubts.
wetmap.hipnc
hello ronit1996, I saw your dialogue and wanted to ask, so that the texture does not appear after the collision and the texture formed, for example, black
