In POP-Fluid, where can I apply noise to the viscosity?
Masoud
Hello;
In Houdini 16.5, I would like to add "viscosity" to a "Particle Fluid" simulation using a noise pattern, so in DOP I add a "POP-VOP" node (and AANoise in it ... ) after "Source Volume" which doesn't work.
Where could I apply noise to the viscosity?
Thanks for helping.
Viscosity.hip
Edited by Masoud
26 minutes ago, thebrettwalter said:
bypass the fit and you got noisey viscosity....
looks like your fit is pushing visc values into positive ++
I think I should use the "fit" because "Anti-Aliased Noise" creates an output from -0.5 to 0.5 and I also need the viscosity from 1 to 500.
