How to reduce dot particles using point wrangle?
maulen
1. use Unpack Points SOP instead of Convert VDB Points
2. you don't have @id attribute on your points, and you are compressing the points so having a valid @id on them is crucial, so make sure you enable id on your solver, recache and you should be fine
if however you really need to reduce only a single frame or you decide to recache without reseeding and without compressing, making sure your pointcloud is stable and you don't need @id, then you can use @ptnum in rand function instead
if (rand(@ptnum, chf("seed")) < chf("percent") ) {
    removepoint(0, @ptnum);
Edited by anim
