Sweep roll curve in Houdini 18.0.391
4n7
I'm trying to roll a sweep node 90 degress but it never lines up, I've tried a bunch of options in roll, yaw, pitch but can't get it to look right or line up.
What's the best tool to use for this?
I think what I'm asking is how to smooth the transition or lose the m style for a round shape, i see lots of posts with an older version of sweep, not sure how to get $PCT or a ramp into the 'roll' section
Thanks in advance
SweepCurve.hiplc
Edited by 4n7
update
hopefully I've understood what you want, so you want the middle joint to be perfectly lined up right ? (ignoring the 'slight' angle at each ends)
if so, simply centre your cross section first
vu_SweepCurve.hiplc
actually, maybe I don't know exactly what you want...furgedd it LOL.
Edited by Noobini
  • Thanks 1
how about 2nd chance,
change your track curve to NURBS, both ends would be perfectly lined up, the divisions however are a bit out and the ends...you may not care about this...or remesh...or whatever, dunno.
Edited by Noobini
  • Thanks 1
Thank you both, this exactly what I was after, after searching I saw orientalongcurve was part of the new sweep node, I just have no idea how to implent it, this is exactly what I was after so thank you, I now have a smooth banked curve
I'm using the attribute wrangle from @Aizatulin
float u = float(@ptnum) / (@numpt - 1);
@roll = chramp('roll', u);
This works perfectly, many thanks
