Foxhound Posted May 3, 2020 Share Posted May 3, 2020 Good day to you Houdini magicians out there! I have been following the Particles IV Tutorial by Steven Knipping (the one with the cherry blossom petals) and as i did with the previous tutorials i always found a workaround to get it to work with Redshift... except for this one and it makes me go nuts. On the surface level everything is working as intended, except for the materials. I've tried applying the shaders on the actual instancing items, even stuff like applying the material onto the instance itself.The materials are also set up to read the Cd attributes and i checked that the Cd attribute isn't replaced or erased somewhere. Can somebody help me? Did someone out there stumble upon the same problem and found a fix. If needed i can provide the .hip file. I know it's not a too big of a problem but it's bugging me really bad. I am thankful for every bit of help! Quote Link to comment Share on other sites More sharing options...
Librarian Posted May 3, 2020 Share Posted May 3, 2020 Denis post..hip and someone gonna help you Quote Link to comment Share on other sites More sharing options...
Foxhound Posted May 3, 2020 Author Share Posted May 3, 2020 (edited) 26 minutes ago, Librarian said: Denis post..hip and someone gonna help you Yes Sir! cherryblossoms.hiplc here you guys have the file, hope that you can open it! Edited May 3, 2020 by Foxhound Quote Link to comment Share on other sites More sharing options...
