Wout Posted May 4, 2020 Share Posted May 4, 2020 (edited) Hi, I started working on a grass pack that I'll put on Gumroad. I'm off to a good start I think. Even with just one blade of grass instanced it's already looking pretty good Wout Edited May 4, 2020 by Wout 3 Quote Link to comment Share on other sites More sharing options...
Wout Posted May 9, 2020 Author Share Posted May 9, 2020 Little update : Placement , 4 grass blades variation, shading work. Houdini is awesome but when it comes to (random) rotations.. PHEW, down the rabbit hole haha Quote Link to comment Share on other sites More sharing options...
Librarian Posted May 10, 2020 Share Posted May 10, 2020 hope it Helps .. Quote Link to comment Share on other sites More sharing options...
Wout Posted May 10, 2020 Author Share Posted May 10, 2020 (edited) Hi Librarian, thank you for taking the time to make that example. The issue I'm running into though, is doing a copy to points, which aligns the+Z axis to the normals, and then keeping that alignment + adding random rotation. Random rotation on flat plane is pretty straight forward but once you start adding deformation, stuff goes weird *Edit: Come to think of it, maybe adding the random rotation before the copy to points would work, but then I would still need to recreate the alignment from the copy to points node, as I'm using it on instances;; hmmm Edited May 10, 2020 by Wout Quote Link to comment Share on other sites More sharing options...
Librarian Posted May 10, 2020 Share Posted May 10, 2020 I hope that your Grass Taste better than I mean (LOOK) NJam . Have fun. Sorry for any mistake (nice tricks ) 16.5 Houdini GrassHeaven.hipnc Quote Link to comment Share on other sites More sharing options...
Wout Posted May 10, 2020 Author Share Posted May 10, 2020 Oh that's funny, I came across the website with that example yesterday Thanks ! Quote Link to comment Share on other sites More sharing options...
Librarian Posted May 10, 2020 Share Posted May 10, 2020 Quote Link to comment Share on other sites More sharing options...
Wout Posted May 12, 2020 Author Share Posted May 12, 2020 (edited) Update I spent like two or three days trying to figure out a way to align an object to the normals of another object combined with local random rotations but I finally figured it out It works very well but it is a bit slow. Edited May 12, 2020 by Wout 2 Quote Link to comment Share on other sites More sharing options...
Librarian Posted May 12, 2020 Share Posted May 12, 2020 You have the plan to do something like this * https://www.toadstorm.com/blog/?p=534 https://www.artstation.com/artwork/oO6OQW or you gonna throw some stones on the grass. Quote Link to comment Share on other sites More sharing options...
Wout Posted May 12, 2020 Author Share Posted May 12, 2020 (edited) I'm probably gonna add some more grass blade variations and then some other things you'd find in a field of grass, like clovers, or small weeds and stuff like that Or maybe throw some stones on the grass haha Edited May 12, 2020 by Wout Quote Link to comment Share on other sites More sharing options...
Wout Posted May 12, 2020 Author Share Posted May 12, 2020 Yessss, starting to look very real.. I'm happy with my progress 1 Quote Link to comment Share on other sites More sharing options...
flcc Posted May 12, 2020 Share Posted May 12, 2020 It's time to pass the Lawn Mower ! Quote Link to comment Share on other sites More sharing options...
Wout Posted May 13, 2020 Author Share Posted May 13, 2020 Haha yes, if your back yard looks like that.. I'm going for a meadow with this one Quote Link to comment Share on other sites More sharing options...
Wout Posted May 14, 2020 Author Share Posted May 14, 2020 Made the grass a litlte flatter/closer to the ground and I added clovers Quote Link to comment Share on other sites More sharing options...
Wout Posted May 14, 2020 Author Share Posted May 14, 2020 Quote Link to comment Share on other sites More sharing options...
Wout Posted May 14, 2020 Author Share Posted May 14, 2020 (edited) In the render above I manually selected points with the lasso to instance the clovers on. In this render I used a noise pattern to determine were the grass should be flatter and at the same time that's where the clovers are instanced. I also did some shader tweaking. Edited May 14, 2020 by Wout 3 Quote Link to comment Share on other sites More sharing options...
Librarian Posted May 14, 2020 Share Posted May 14, 2020 Beauty ...Dreaming(Ganja- me- Wife and Stampstamp (mmmmmmmmmmm)) nicely Done Quote Link to comment Share on other sites More sharing options...
Wout Posted May 14, 2020 Author Share Posted May 14, 2020 (edited) I'm not entirely sure I understand what you're saying in the first part but that's okay * Edit: Do you mean smoking weed and making love ? haha Thank you ! Edited May 14, 2020 by Wout Quote Link to comment Share on other sites More sharing options...
Librarian Posted May 14, 2020 Share Posted May 14, 2020 Bingo Quote Link to comment Share on other sites More sharing options...
Wout Posted May 14, 2020 Author Share Posted May 14, 2020 WE HAVE A BINGO ! hahaha Quote Link to comment Share on other sites More sharing options...
